  • 22 Vote(s) - 3.36 Average
FACC sliding gate not responding.
Hi everyone
It was working fine until a few months ago and then it stopped. (doesn't respond to the remote)
This is an old model (FAAC 746 SD1), I uploaded a photo of the engine and the control panel. Hoping that you will help to see what the next steps are in diagnosing the cause of the problem.
How can you bypass the remote control and start the engine manually?
I would be happy to receive assistance and try to solve the problem with your help.
So today I was able to open the gate manually by bridging point 2 to point 6.
I also discovered that the receiver of the remote does not receive the voltage of 12V that it should receive, therefore it does not work.
Now I ask myself how to fix the problem that there is no power supply from the control board, and is it possible to use an external power supply to power the gate?
(03-12-2024, 12:21 PM)Kipod Wrote: So today I was able to open the gate manually by bridging point 2 to point 6.
Have you checked the fuse for 12V power supply? You can also use external 12V power supply but check the fuse maybe you just need to replace it
  FAAC S800 Single swing Gate not responding robhight 0 4,010 18-11-2024, 11:48 AM
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 10,014 22-04-2024, 03:21 PM
  Gate continues trying to open tjtj6554 1 9,354 20-09-2022, 08:02 AM
  Faac gate opens when photo cell beam is broken Stephen Q 5 21,403 29-03-2021, 01:53 PM
Last Post: Stephen Q
  Fine tuning gate stopping point jwcgc629 0 7,892 11-12-2020, 04:53 PM
Last Post: jwcgc629
  FAAC Gate Issue asifrana 0 12,122 26-07-2020, 10:53 PM
Last Post: asifrana
  Trouble keeping gate closed tkalfaoglu 0 9,482 28-06-2016, 10:02 AM
Last Post: tkalfaoglu
  Difficulty installing Faac gate opener grigadale 1 17,031 31-07-2012, 04:17 PM
Last Post: acsys
Question Do I need to use the same manufacturer to replace my gate remote control? danemo 1 16,511 31-03-2011, 12:45 PM
