  • 23 Vote(s) - 3.04 Average
Mhouse left gate not closing properly
Sometimes my left gate closes with no problem but more often it starts to close but then stops and reopens - if I close again straight away it closes with no problem - so I’m thinking this isn’t a mechanical problem as it always closes fine on the second attempt - anybody have any ideas?
Opens fine by the way every time.
Usually this is related to the motor drawing too much current causing the control panel to trigger a safety function as it thinks there is too much friction and relates this too an obstacle being present. I would first check if the ram requires greasing to alleviate as much friction as possible on the arm mechanics. I would also check the if you are able to open and close the gate freely with the arm manually released, I would advise moving it by holding onto the motor bracket, moving the gate at the end of the leaf will not give an accurate feel as this is not where the motor pulls and pushes on the gate. It would also be advised to check the mounting A and B measurements as if they are slightly out of the manufacturers guidelines it can put strain on the motor over time and cause faults like this to occur
To check whether the motor is causing the gate to reverse or the panel I would advise to swap the motor terminals over, if the issue persists on the same motor it will be relating to that motor directly. If the swaps to the other motor it could be relating to a potential control board issue.
How long has the system been installed?
(05-02-2021, 10:48 AM)RyanB Wrote: Hi,
Many thanks for all this information- much appreciated.
The system has been installed for nearly 20 years now, so I guess it wouldn’t be a surprise things are starting to go a bit strange.
I’ll try your suggestions - many thanks again for your help with this.
  Mhouse sl10 not closing Mark Reader 1 6,229 13-03-2025, 09:56 AM
  MHouse Sl1 does not open v.ptohides 1 6,307 03-02-2025, 09:56 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 8,177 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 10,452 30-01-2024, 10:35 AM
  Where can I find Electric sliding gate opener NICE ROBUS Spare Parts Mogahid Abbas 1 4,811 29-08-2023, 08:40 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 8,749 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 31,450 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 14,387 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 8,506 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 17,054 30-05-2022, 09:15 AM
