  • 199 Vote(s) - 2.97 Average
Q60A/R motor problem
Hi my gates stopped opening. Error code is n1 motor problem (Q60A/R)control unit.checked fuses and capacitor where can I look from here.thanks in advance
(11-01-2017, 09:05 PM)Johnmc Wrote: Hi my gates stopped opening. Error code is n1 motor problem (Q60A/R)control unit.checked fuses and capacitor where can I look from here.thanks in advance
you can check engine rezistance or even powered engine up by 230v bypassing control board .
regards
hi bypassed main board and powered up no movement from motor . Am I looking at replacing the motor.
(12-01-2017, 06:02 PM)Johnmc Wrote: hi bypassed main board and powered up no movement from motor . Am I looking at replacing the motor.
have you got some motor picture , label with tech data
regards
Hi hope this photo will help
did you check motor rezistance ?
did the motor make any noice when was powered up . ?
regards
Hi checked resistance all ok ,when I press the fob the relay clicks and the motor turns for a second and cuts out error code n1 appears
what happened when you bypassed control board ?
to start only motor direct from 220 power source you have use capacitor too ,did you ?
Hi. This time I did use capacitor the motor turned fine smooth no effort to open gate. Hope this sheads some light
#10
(15-01-2017, 11:33 AM)Johnmc Wrote: Hi. This time I did use capacitor the motor turned fine smooth no effort to open gate. Hope this sheads some light
if motor turned in both diretions we know its fine.
try opening your gate manualy by your hands there could by some mechanical problem with motor bracket or gate
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 63,372 09-01-2026, 10:03 AM
  q60a stevea 1 2,766 23-08-2024, 12:14 PM
Last Post: stevea
  Photocell Problem marcoos_1 4 29,007 04-01-2024, 10:23 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,855 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,586 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 5,911 10-02-2023, 03:19 PM
  Nice motor Vandamme911 1 5,277 01-12-2022, 10:31 AM
  Beninca bob motor wiring to board Ranch2 6 13,795 18-11-2022, 09:59 AM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,853 12-07-2022, 11:48 AM
  proteco q60a microcontroller program arashkhan 1 5,867 17-06-2022, 01:29 PM
