  • 427 Vote(s) - 2.85 Average
> Copy your old or broken remote controls with our CL400 copying remote! <
Smile
If you have remote controls that are now discontinued or too expensive to replace, then we have a solution!
Our CL4000 cloning remote is an affordable and modern replacement for your existing remotes.
If your existing remote is on the 433mhz and is Fixed Code then the CL4000 will most likely copy your remote.
You can tell if your remote is fixed code if it has little dipswitches inside.
The CL4000 is only £23+VAT and is very easy to use and programme.
To see more details and to purchase the CL4000 see here:
http://www.easygates.co.uk/universal_remote_control.asp
Heres a selection of the remotes that can be cloned by the CL4000:
[Image: remote-list.jpg]
Simple 4 Step Programming Instructions
1. Clear memory and prepare for programming - Hold down buttons 1 and 2 until the blue LED fashes - this takes around 20 seconds.
2. Place the original and the clone remote close together.
3. Press the button to be programmed on both remotes and hold until LED fashes steadily on the clone remote.
4. Programming is complete - Repeat steps 2-4 to program extra buttons.
http://www.youtube.com/watch?v=CbrZd6d1zG8
  TELECO TVPRP868A09 new remote Goadby 1 10,945 29-11-2023, 09:32 AM
  Replace Remote Control H-055 agafed 2 21,315 02-11-2023, 02:51 PM
Last Post: Matt Turner
  CAME REmote Peter Spaughton 1 12,132 03-07-2023, 08:52 AM
  Replacement garage door remote controller arturorv00 1 13,372 26-04-2023, 09:16 AM
Sad Remote for Proteco Q36a Board ProtecoUser 0 22,972 05-03-2018, 09:22 PM
Last Post: ProtecoUser
  Replacement garage door remote james_m_nutt 2 27,523 17-06-2017, 03:25 PM
Last Post: james_m_nutt
  Intermitent Remote Control Cause/Repair saronson 0 14,923 24-10-2016, 02:06 AM
Last Post: saronson
Question Nice ON2 remote programming problem Annie 1 22,580 11-12-2012, 12:34 PM
