  • 27 Vote(s) - 3.11 Average
Wired up but not working
Hello i have a Beninca brain and beninca bob motors with outer and inner limits with com all wired up ready to go.  But during auto set up it displays the error 6 code which says safety edge has intervened but i do not have one installed when i run the motors off the battery they work fine but just manually with direct power feed to the motors are working but not from brain maybe i got it all wrong
is there a way to force the motors to work from the brain and anyone got the process from switching on to learning the brain how it all works
just lets say i just installed a new system what is the process to get the system up and running many thanks in advance
Is it the 230v or 24v control board you have?
Regard
Mike
(14-11-2022, 11:56 AM)Michael Wrote: Hi,
Regard
Mike
Regard
Mike
24 volt i have connected it up as per wiring diagram but does not do anything when switched on if i go to the auto it says the error
Regard
Mike
here is a picture of the board
Regard
Mike
Solved this one with a bit of help even though the edge protector is not fitted it needs looped out not only with a wire, but it must have a resistor in the wire to simulate a leading edge.  The solution i used was to connect a leading edge to the terminals and the system was happy and allowed test operation no fault present for leading edge hope this makes sense to all
Ranchs2 Wrote:
Michaesl Wrote: Hi,
Regard
Mike
Regard
Mike
Solved this one with a bit of help even though the edge protector is not fitted it needs looped out not only with a wire, but it must have a resistor in the wire to simulate a leading edge.  The solution i used was legal steroids to gain muscle quick to connect a leading edge to the terminals and the system was happy and allowed test operation no fault present for leading edge hope this makes sense to all
Troubleshooting Common Keypad Problems · Where is the keypad located? The keypad needs to be located a minimum of 6 feet from your automatic gate so you cannot
(17-11-2022, 04:36 PM)CharlesZamora Wrote:
Ranchs2 Wrote:
Michaesl Wrote: Hi,
Regard
Mike
Hi Charles,
A keypad can be placed in any proximity to a gate automation system. The only issue would be if that the low voltage power cables were in the same conduit as a 230v power cable, this would cause interference/ EMF
  Gate transmitters intermittently working Nice MC824H solihul 0 151 19-01-2026, 10:22 PM
Last Post: solihul
  Faac photocell stopped working Zeb Gulickx 2 8,534 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  Rigel 5 - second keypad stopped working HarefieldHse 1 5,121 03-07-2023, 08:48 AM
Exclamation Proteco Q60A stopped working xCO 0 3,594 19-06-2023, 01:03 PM
Last Post: xCO
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 12,401 02-12-2022, 02:51 PM
  Faac 740 - stops working norberto 1 10,866 02-06-2020, 05:15 PM
Last Post: norberto
  Getting motors working together Rich123 0 9,052 22-09-2019, 04:44 PM
Last Post: Rich123
  Daitem Wireless Intercom caller unit not working GemOpy 2 24,359 02-10-2017, 10:47 AM
Last Post: GemOpy
  FAAC 750 Deceleration not working bamforp 1 12,657 20-02-2015, 04:54 PM
Last Post: bamforp
  Gate remotes stopped working Steviev1 1 17,755 03-01-2015, 12:01 PM
