  • 26 Vote(s) - 3.15 Average
BFT Thalia no power on accessory ports (50, 51)
I am trying to draw port from ports 50, 51 which should provide 24V, however there is none. I checked all the fuses, and they all seem to be good. What else can I check?
(20-08-2024, 06:24 PM)tjomk Wrote: I am trying to draw port from ports 50, 51 which should provide 24V, however there is none. I checked all the fuses, and they all seem to be good. What else can I check?
If you have metered for voltage and are still not getting a reading between the two contacts then it sounds as if the 24V outputs must be faulty.
Jake
You will possibly find that they energise when the gates are in operation and shut off again when they stop. They should not do that as terminal 52 is the one that is set to safe but mine was exactly the same and I had to take a separate feed for my ground loop, which needed a permanent supply.
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,362 03-02-2025, 12:24 PM
  Accessory Power Caesium 5 20,923 08-05-2024, 09:02 AM
  Thalia - Photocell Close J to the D 1 4,048 19-01-2024, 09:54 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 14,091 24-08-2023, 01:38 PM
  Thalia P - Wireless control board module mathewnorris22 1 7,085 02-03-2023, 03:17 PM
  thalia error code 3h 35/37/38 detritus 1 6,306 05-01-2023, 11:54 AM
  BFT photocell low power/no power kmeand 2 12,166 03-08-2022, 01:47 PM
  BFT Thalia button djbananas 3 9,863 19-04-2022, 09:14 AM
  BFT Thalia GSM gate opener SunnyB1 1 6,727 07-03-2022, 10:58 AM
  Lux/Thalia P ersl error Dava12 0 4,988 13-12-2021, 09:35 PM
Last Post: Dava12
