  • 23 Vote(s) - 2.7 Average
Gate not closing
Configuration: Double gate, remote control open gate input, exit open gate switch, intercom open gate contact, induction loop to open gate
After years of normal operation the gate was opened with a remote control and stayed open, refusing to close (it is programmed to close after 10 seconds or so). The photocells clicked OK. Eventually it *closed* after a car went over the induction loop and then operated normally from then on.
Does the controller maybe have a "keep gate open" functionality such as double press on the remote or press the remote for X seconds, which activates the keeping of the gate in an open position? (BTW, that would be a very useful function if it does not have it).
I tried powering the system off and on several times while the gate was open and refusing to close - no effect.
To help with your query we would need to know the specific panel or kit you have. Some panels when having a double activation such as a remote activation then loop activation (when drove over) before the gates have fully opened this can send a stop signal to the gates and override the automatic closure.
The panel would need the 'apartment block' or 'condominium' mode set to ignore the double activation and function on open-close-open-close only. So when the gate is in travel no stop command is given to the motors.
I hope this helps
  BFT Gate Motor - Not working elyoussef.ali 1 6,484 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,265 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,643 21-07-2025, 06:54 AM
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,365 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,795 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,546 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 5,030 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,308 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,217 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 17,434 11-04-2024, 08:08 AM
