  • 294 Vote(s) - 2.78 Average
aster 5 gate adjustment
my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Guest Wrote:my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Hi, you should have physical gate stops in the ground to stop the motor running to the end of its reach. also there should be a function on the board to decrease the motor run time, or there maybe a function to learn where the gates open and close to. you should refer to the manual for this information.
Hope this helps
  Gate transmitters intermittently working Nice MC824H solihul 0 149 19-01-2026, 10:22 PM
Last Post: solihul
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 1,135 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 63,369 09-01-2026, 10:03 AM
  Help me identify this mystery gate opener alpha 5 6,163 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,706 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,747 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 5,242 28-03-2025, 03:15 PM
Last Post: mitasali
  Nice Swing Gate Opener nicenotnice 0 4,733 18-03-2025, 06:40 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 14,668 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,401 16-11-2024, 09:25 PM
Last Post: thronetm
