  • 360 Vote(s) - 2.9 Average
LiftMaster CB11 Board Photocells
I have installed the easygate under ground system for double gate with CB11 control board . The close , open photo sensors are connected to the correct pins with correct polarities . Some how the close sensers do not work .if I swope the two ie with pins 17 and 18 only pin 18 works . The voltage on pins 17 is 24v ac/dc on pin 16 is 15volts ac/dc pin 19 is 24volts ac/dc . This is a new instalation can some one help on this .The sensors are all ok . The setup procedure has been done for the photo sensors .
The connections you are sujesting is completly wrong for the CB11 control board it should be :
Open Photocells - pins 21(+) & 24(-)
Close Photocells Pins 22(+) & 24(-)
Open/Close photocells pins 23(+) & 24(-)
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 740 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 27,342 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Liftmaster LA400 Defender 6 22,569 03-08-2023, 12:26 PM
Last Post: Torantrieb
  CB11 Multiple Keypad support Pigsfoot 1 5,366 12-08-2022, 08:14 AM
  odd liftmaster scs300-24 scopie88 3 21,663 13-04-2022, 10:20 AM
  Problem with delay time CB11 milan 2 15,070 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 19,553 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 23,632 22-02-2021, 08:48 PM
Last Post: russ
  Adding Extra Photocells To CB22 Onoff 0 7,407 06-08-2020, 01:01 AM
Last Post: Onoff
  Liftmaster CB1 gates started to open themselves telnet123 4 35,613 01-01-2020, 09:43 AM
Last Post: pronosoft
