Electric Gates, Garage Door, Access Control, Smart Home & Security Forums
Came ZM3E - Wont open from keypad - Printable Version
+- Electric Gates, Garage Door, Access Control, Smart Home & Security Forums (https://www.gateguide.co.uk)
+-- Forum: Gate Automation and Installation Help (https://www.gateguide.co.uk/forumdisplay.php?fid=1)
+--- Forum: CAME Automatic Gate Openers (https://www.gateguide.co.uk/forumdisplay.php?fid=4)
+--- Thread: Came ZM3E - Wont open from keypad (/showthread.php?tid=7440)
Came ZM3E - Wont open from keypad - geoff_n - 16-12-2025
I have a Came ZM3E which is working fine from all the remote fobs and the sub ground pressure plate, happy days you would think!
However, when I key in the previously working 4-digit gate code from the Came BPT Targha entry system, it beeps and then lights the amber warning light.
I’ve tried the usual power on / power off to no avail. The gate code hasn’t been changed, and I don’t touch the internals of the ZM3E.
Does anyone know if there is any way I can check an error code to troubleshoot this please ? Is it possible that the gate code has reset to system defaults ?
Just seems odd its working fine in all other situations, it just wont open from the keypad.
Many thanks for any help!
RE: Came ZM3E - Wont open from keypad - Prem - 08-01-2026
It may be possible to find a reset. What's the model number of the keypad?
Prem
RE: Came ZM3E - Wont open from keypad - geoff_n - 09-01-2026
Thanks for getting back to me.
Its is a  BPT HSC-1ST 1-Button Surface Targha Audio Entry Panel
ADI#: HSC/1ST
Model#: HSC/1ST
